Front axle housing seal
Old Apr 11, 2007 | 02:39 AM
Jonah Hex's Avatar
Jonah Hex
Default Front axle housing seal
Hi Everyone,
I know that at least 1 or 2 of you have replaced the the front u-joints on your 4x4 Ram. My question is this....where do you find the seals that are pressed onto axle shafts that cover the gap between the front axles and the axle housing? I replaced the passenger side u-joint last week and have been unable to find this seal ANYWHERE. I would like to replace them because I don`t want my axle tubes full of debris.The old one separated when I pulled the axle out.
It is marked on the outer ring.......Forsheda Made in the USA Patented A083612 49254
Any help would be greatly appreciated!
Jonah
Old Apr 11, 2007 | 03:33 AM
dhvaughan's Avatar
dhvaughan
Default RE: Front axle housing seal
try someplace like this that sells Forsheda products. Maybe they can get that part number.
unbelievable that dodge doesn't provide them. reckon what they do when they replace ujoints ?
(leave them out i guess)
http://www.mspseals.com/mro.asp
Old Apr 11, 2007 | 01:08 PM
Jonah Hex's Avatar
Jonah Hex
Thanks dhvaughn, I found that website when I googled Forsheda. The website does not have much info that can be accessed, so I guess I will rip them off an email.
I went to the Dodge dealership, and they show theseal as part of the front axle assembly, but it doesn`t have a separate part number. I wasn`t interested in buying a whole new axle to get a $10.00 seal!
Thanks again for the reply.
Jonah
Old Apr 11, 2007 | 08:23 PM
DODGE 4X4's Avatar
DODGE 4X4
when i replaced my u joints i didn't have a problem with the seals but a week after the fix i find out the 4 wheel drive doesnt work any ideas
Old Apr 12, 2007 | 02:23 AM
Jonah Hex's Avatar
Jonah Hex
Dodge4x4 ,
I remember reading your query in another thread....check to see if the vacuum line is connected to the cannister on the front axle, along with the electrical connector. My next thought was to check the relay in the pcm under the hood. Failing that, check to make sure that the bulb is not burnt out, stranger coincidences have happened! Good luck!
Jonah
Old Apr 12, 2007 | 03:28 PM
Socha_62's Avatar
Socha_62
Try a Dana dealer. Your talking about the plastic piece? I don't even think mine has them.
