where to get injectors
Old Apr 15, 2007 | 02:23 AM
asimpson97d's Avatar
asimpson97d
Default where to get injectors
Anyone know where to get a good set of 30 lb. injectors for my 2nd gen. 5.9?
Old Apr 15, 2007 | 09:35 AM
turkeyhunter1962's Avatar
turkeyhunter1962
Default RE: where to get injectors
What you looking for 30 lb injectors for? The Fastman's 408 stroked 12 second Dakota is only running 24 or 26 lb injectors.
I've seen the fuel injector calculators on a number of websites and the value they provide is the top horsepower value andI believe they are even high with their calculations.
If you're running a 360 the basic ECM programming will only handle the stock size injectors which I believe are 19 lb. The only way to use larger injectors is to have your ECM custom programmed from B&G or somebody as good. The stock 360 would still not handle the 30 pound injectors. Keep the engine tuned with stock injectors and you'll get plenty of power out of the 360.
Old Apr 15, 2007 | 04:34 PM
asimpson97d
I should've been more specific...Building a motor through Hughes Engines and thats what they suggested I use so...where can i get a good set of 30# injectors. I don't carewhat the fastman is running.
Old Apr 15, 2007 | 05:05 PM
RM_Indy's Avatar
RM_Indy
You can get some matched 30lb Ford Motor sport injectors from fivieohmotorsports.com.they'vegot some really good prices.(think thats the name/Ill check)
Old Apr 15, 2007 | 06:03 PM
RM_Indy's Avatar
RM_Indy
Seems five oh's not around any more. Guess the prices were too good.
High performance motor should be rated at about a .47-.50 BSFC and 80% duty cycle on the injectors.
My 408/8.5cr needs34lbs injifits runningNA. I went with FAST stand alone and 65lb injectors that can support up to 14psi boost.
Old Apr 15, 2007 | 07:01 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: RM_Indy
so when are we gonna see the 408 on boost down the track?
Old Apr 15, 2007 | 07:52 PM
turkeyhunter1962
I purchased my 22lb injectors through Motorman fuel injection supplies. http://www.injectors4u.com/. Thanks for the additional info. Now it makes sense. Good luck with your build.
Old Apr 15, 2007 | 10:42 PM
asimpson97d
Thanks boys. So you guys wouldn't suggest (though I don't know if they even make them) Accel or Venom? RM_Indy: did you have to change anything to make your injectors fit?
