95 ram 4x4 want to get 15' rims/35" tires?
Old 04-18-2007 | 09:19 PM
hkspwrsche's Avatar
hkspwrsche
Default 95 ram 4x4 want to get 15' rims/35" tires?
Any suggestions for tires and wheels for a 95 dodge ram 4x4with 6in lift. 3susp and 3 body.
I wanted to go to 15" to get the floatation sizes such as the 35" -They will work I assume?
Thanks
Harold
Old 04-19-2007 | 12:27 AM
DieselDemon's Avatar
DieselDemon
Default RE: 95 ram 4x4 want to get 15' rims/35" tires?
I don't think you'd clear the calipers. I could be wrong.
Good luck with your ride.
Old 04-19-2007 | 01:25 AM
hkspwrsche's Avatar
hkspwrsche
No one else has 35/12.50/15s on a 95 ram 4x4?
I posted a question before about what size I should go with to fill the 6 inches of lift and didnt get much response.
Old 04-19-2007 | 01:43 AM
stick1994's Avatar
stick1994
Eagle alloy 15's worked on mine
Old 04-19-2007 | 02:28 AM
TMS Bill's Avatar
TMS Bill
I believe it's the later model dual piston calipers that the 15" rims are a crap shoot on. Singles are probably a go.
Old 04-19-2007 | 02:58 AM
hkspwrsche's Avatar
hkspwrsche
I thought I had seen that size.Thinking about 15x10 and 35 /1250 /15.
Old 04-19-2007 | 04:21 PM
hkspwrsche's Avatar
hkspwrsche
Will 35x1250s fit on the 15x8?
Old 04-19-2007 | 06:28 PM
Frye's Avatar
Frye
You may rub a little, but just get a sledge hammer and pound that sucker in. I have 10 inches of lift, 6 inch susp 4 inch body, had 35X14.50X15 swamp suckers, then changed to 37X14.50X15 toyo open country MT's. They rubbed a touch but I hit it down with a sledge now I am fine. Won't have a problem with the calipers.
Old 04-20-2007 | 01:53 AM
spaz_22's Avatar
spaz_22
you'll be fine with 15's on your year of dodge, I believe the changed the calipers to dual in 98 or 99 and that's when you have to go to a 16, you can use 15's but you'll have to grind the caliper. 20dodge01 has 15's on his 2001. 35x12.50x15 will work great with your 15x8 rims. you shouldn't run into any problems with rubbing
Quick Reply: 95 ram 4x4 want to get 15' rims/35" tires?
