Is this normal?
Old Apr 20, 2007 | 07:30 PM
Works4Ford's Avatar
Works4Ford
Default Is this normal?
I got under the truck the other day and I turned the front driveshaft while the truck is in park. Is it normal for the front driveshaft to turn freely without the front wheels moving? Is there something that engages the front driveshaft to the axles when you put the truck in 4wd?
Old Apr 20, 2007 | 07:33 PM
tobba's Avatar
tobba
Default RE: Is this normal?
Yea, there's a vakuum enganged thing on the left driveshaft, it will engage when you put the truck in 4wd
Old Apr 21, 2007 | 12:38 AM
TMS Bill's Avatar
TMS Bill
ORIGINAL: Works4Ford
The xfer case was not engaged and the CAD has not locked the right axle halves ... so you were turning the driveshaft, the differential carrier and the right inner axle half ... 100% normal.
Old Apr 21, 2007 | 12:39 AM
Ram_Sport's Avatar
Ram_Sport
ive done this before, its quite wierd but it is one of the things that saves gas a lil vs. the alltime xfer case
