leak by wheel
Old Apr 20, 2007 | 11:40 PM
shizzaybizzle's Avatar
shizzaybizzle
Default leak by wheel
Today I noticed there was a black fluid leaking out by the wheel. I don't know exactly what the part is that is leaking but its by the inside wheel. Any ideas?
Old Apr 21, 2007 | 12:44 AM
TMS Bill's Avatar
TMS Bill
Default RE: leak by wheel
Could be brake fluid (looks black on the tire) or differential oil. What's it smell like ... really rank or kinda alcohol-like?
Old Apr 21, 2007 | 12:45 AM
shizzaybizzle
it smells like some kind of greese. someone said it could be the axle.
Old Apr 21, 2007 | 12:49 AM
TMS Bill's Avatar
TMS Bill
Sounds like you have a leaking axle seal.
Old Apr 21, 2007 | 03:26 AM
shizzaybizzle
how much would that cost to fix? it stopped leaking... is it bad to drive it now?
Old Apr 21, 2007 | 07:58 AM
froesen's Avatar
froesen
Is this the front or rear axle? If it's the rear axle it's no big deal to fix, pull the shafts (remove pin in carrier and c-clips) and change seals (probably brake shoes too as they'll have oil on them). If it's the front axle, it's a little more work to change the seals, drivers side the carrier needs to be removed, passenger the CAD motor and axleshafts, and a special tool is required to pull the seals into place. As long as you keep track of diff fluid level, and remember that your brakes may not work as well as they should, it'll be fine to drive for a bit. When something stops leaking it's usually a worse sign than when it was leaking...means there's nothing left to leak out....although with the diff it just means the level has dropped to below the level of the bottom of the axle tubes, right around where it usually sits. When you go around corners fluid will get to those areas again.
Old Apr 21, 2007 | 01:37 PM
shizzaybizzle
how can I tell the fluid level?
Old Apr 21, 2007 | 05:57 PM
DieselDemon's Avatar
DieselDemon
How about starting with maybe the YEAR and MODEL of your Ram?
Carnac is not always taking new clients.
[IMG]local://upfiles/12792/D69E1BA0F2DC40BBAE62D5B1F4098632.jpg[/IMG]
Old Apr 21, 2007 | 09:44 PM
shizzaybizzle
1998 ram 4X4 5.9 liter
Old Apr 21, 2007 | 09:50 PM
DieselDemon
That would be a 1500 or 2500?
