noise on left front
Old Apr 22, 2007 | 10:29 AM
spd132's Avatar
spd132
Default noise on left front
I just bought a 97 ram 1500 4x4 ex-cab 5.9L. While driving yesterday, I noticed a popping noise coming from I think the left front. As long as I am going straight, it doesn't make a sound. It only does it when I am making a turn. There is no play in the steering and when I hear the noise I can't feel anything throught the steering wheel. Does anyone have any idea as to what could be making the noise? I bought the ram from an individual for $4700. As far as body, interior and drive train, you can tell the pickup has been taken care of. I am just worried as to what is making the popping sound.
Old Apr 22, 2007 | 08:21 PM
matt62557's Avatar
matt62557
Default RE: noise on left front
Possible control arm bushings....Can you feel it poppig under your feet?
Old Apr 22, 2007 | 08:23 PM
AAA4948's Avatar
AAA4948
Turning left, right, or both ways? Possibly U-joint...
Old Apr 23, 2007 | 11:38 PM
TMS Bill's Avatar
TMS Bill
Need more information ... repeated popping or only once per turn? Turning one direction or either? Is it speed dependent? Could be shock mount, track bar, ball joint(s), sway bar link ...[>:]
Old Apr 24, 2007 | 05:36 PM
spd132's Avatar
spd132
Sorry it took so long for me to reply. The popping noise could only be heard when i was turning. I went out yesterday and greased everything under the front and the noise stopped. I did check the u-joints and you could feel a very small amount of movement. Does anyone know what could have possibly been making the noise. Speed or going straight didn't cause the noise. Only turning.
Old Apr 24, 2007 | 06:38 PM
bander's Avatar
bander
I dont know how much movement is a little on u-joints but it should be tight.
Old Apr 24, 2007 | 11:53 PM
TMS Bill's Avatar
TMS Bill
I figure it was either a ball joint, the tie rod or the drag link.
Old Apr 25, 2007 | 05:52 PM
mnram's Avatar
mnram
Don't most front u joint's only make noise when going straight when you turn they are quiet or close to quiet?
Old Apr 25, 2007 | 09:50 PM
mopar crazy's Avatar
mopar crazy
ORIGINAL: mnram
That is correct, the noise is only heard while driving straight. When turning, the noise will sease to exist since there is less pressure on the joint from what Ive been told.
Old Apr 26, 2007 | 03:02 AM
asybra00's Avatar
asybra00
Hey all, Im having a kind of similar problem. When i turn either direction and most of the time if theres a small bump in the road i will feel a kind of shift. Like something is loose up front. I dont feel it in my feet but in the steering wheel the most. From what ive read in the post could i assume that its the u-joints going out??
