shaker hood
RE: shaker hood
Dtruck96, I have that hood. It also has large gaps on the sides and I had to play around with the grill to get it to work. I like the hood and have gotten used to the gaps but I think when I get the money, I may have someone cut my steel hood to fit the scoop and re-install it. Heres some pics on mine. Jeff.
[IMG]local://upfiles/43161/F86D0CCB87224BF4BFD49574B78AA5B4.jpg[/IMG]
[IMG]local://upfiles/43161/0D05FD4EEE1843F1926C4B9B9A95F674.jpg[/IMG]
RE: shaker hood
shott8283, it is the Keystone Good Hood. The hood itself is really nice. I'ts thick enough that it doesn't allow a bunch of engine noise in and it's finished off really nice on the underside. It looks to me that they made the sides exta thick where it sits on the fenders but because of this it doesn't sit down as far as the factory hood did. If I would have had the extra cash I would have gotten someone experienced in fiberglass to install it. Maybe they could have made it fit better. There isn't **** for adjustment in the hinges so I basically got it as close as I could and called it done. As far as the grill, I just opened up the 2 end bolt holes on the hood where the grill mounts, then used a large washer on those 2 holes. I was able to get the grill to fit good. This was the 2nd fiberglass piece I bought. I got a roll pan to go on my boys RamCharger and it was a pain to install also although I can't complain about that one because it wasn't made for the RamCharger it was for a Dodge truck. It looked good when done but took a few hours to get it right. It's too bad they don't sell just the scoop because that would be the way to go. Get the scoop and have a good body person cut the factory hood to fit it. Jeff.
RE: shaker hood
Well I finally got it to fit decent. Took some moving of the hinges and the hood itself on the hinges but like jram 99 said I still have gaps on the side. I would post some pics on here but I just bought a new computer and I am having trouble locating the install cd for my camera. Anyways when i find it will put some pics up. Also jram did you experience any squeaking when you put yours on? I am thinking it is the rubber gasket around the scoop. I will mess with it some and see if I can get it to stop. Thanks for the input guys.
Trending Topics
RE: shaker hood
Dtruck96, yes I had the squeeking and it drove me nuts. I finally figured out it was from the flange on the lowerpart of the scoop assembly that connects to the TB rubbing against the firewall in the tunnel. Was a tight fit for sure. I did 2 things to make life easier. I cut off that bolt that hangs down from the left upper side. And I used a power sander to remove enough of the flange at the rear & sidesof the assembly until it didn't rub anymore. Lots of trips around the neighbor hood with no hood, just the scoop until I could hit bumps and slam the throttle without the scoop rubbing the firewall. I also decided to use a nut and washer to hold the assembly down instead of the butterfly nut just for a little extra clearance. Now I have a question for you. You said you were able to adjust the hinges and the hood. I didn't see any adjustment in the hinge, can you describe what you did? My gap is now is only at the rear of the hood where it attaches to hinge. If I could adjust that out, the hood would fit really nice. Like I've said before, I don't know **** about body work!
Indy, I paid about $850 from Summit. That included shipping via truck also. The scoop comes in about 5 main pcs. There's the part that attaches to the TB and also holds the 12 or 14 inch round air filter. Then the top to that pc, then the bottom section of the shaker scoop and then the shaker scoop that goes thru the hood. I think it could have been designed better with fewer pcs but when it's on right and the hoods closed, it looks good. To anyone thinking about this hood, if you get one, take your time make sure each part is on right and you will be happy with it. If you have experience working with fiberglass, you are way ahead of the game. If anyone wants different pictures at certain angles or what ever, let me know. I will be happy to shoot what ever is needed if someone is trying to make a decision on buying one of these. Jeff.
