fault codes on a obd 1 engine
Old May 1, 2007 | 04:41 AM
94ram15004x4's Avatar
94ram15004x4
Default fault codes on a obd 1 engine
I have had 2 fault codes that are always active and have been in the truck as long as i have had it. I was wondering if anyone else has this? Should I worry abotu them? The codes are 12 (bat dissconect within the last 50 key offs) and 37 ( trans temp to high, trans temp voltage shorted, tcc lock up circuit mailfuction( i dont rember the tcc one correctly)).
has anyone dealt with these? my manual doesnt have any trouble shooting steps for them. thanks for the help.
ryan.
Old May 1, 2007 | 10:33 PM
TMS Bill's Avatar
TMS Bill
Default RE: fault codes on a obd 1 engine
The 12 is normal ... the 37 is not. Here's a lot of information on OBD I vehicles. Might even find a fix for yours. http://ezinearticles.com/?OBD1-Codes...&id=188014
Old May 2, 2007 | 03:22 AM
master tech's Avatar
master tech
Site Moderator & Tech
Yes I have, ck the connection at the transmission. If its okay then replace the lock-up solenoid. Need to remove the valve body to replace.
Old May 2, 2007 | 04:50 AM
94ram15004x4
the converter locks up and unlocks when im driving. It seems normal also. I might give it a shot and switch out the switch. Thanks for the help
