TGC lift finished!
Old May 2, 2007 | 02:40 AM
Dodge ram it's Avatar
Dodge ram it
Default TGC lift finished!
All done, took about four hours and went real smooth. I like how the kit looks but.... The front is sitting a little taller than the rear.... Right now I have the inch and a half block in, but, I have a three inch block sitting on the shelf. If I install the three inch block will that be too much for the driveshaft angles and too much of a safety hazard? Or, should I get an AAL and throw that under there? Ill load the pics when my MTR's are on there.
Old May 2, 2007 | 02:45 AM
Dodge ram it
Default RE: TGC lift finished!
For clarification its a 95 ram 1500, 5.9, long bed, 4x4 and the lift was the three inch coil spacer from TGC's.......
Old May 2, 2007 | 02:56 AM
20dodgeram01's Avatar
20dodgeram01
a AAL would be better.. but a 3 inch block is fine.. theres 5 inch suspension kits with 5 inch blocks in the rear.. just make sure you crank those u-bolts down tight and keep checking them
Old May 2, 2007 | 08:11 PM
Dodge ram it
Just to confirm that It wont mess with the drivesaft angles or any other funcion of that? Keeping in mind that its a three inch block ontop of a stock 1500 series block thats already there from the factory.....
