Vacuum Problem?
Old May 11, 2007 | 12:41 AM
dodgeram98's Avatar
dodgeram98
Default RE: Vacuum Problem?
Got the vacuum canister today. Works like a champ. Thanks alot!!!!!
For lucas3397, my truck didn't come with the canister type. It had a small
check valve about the size of a quarter with nipples on each side. It was located
inline next to the dryer. Hope this helps.
Old May 11, 2007 | 03:27 AM
lucas3397's Avatar
lucas3397
Alrighty then I'll check it out. Thanks
Old May 11, 2007 | 10:52 AM
TPSDODGE's Avatar
TPSDODGE
yeah nobodys trk came with it it was released later as a tsb
Old May 11, 2007 | 05:50 PM
73scoutII's Avatar
73scoutII
Ok mine is fixed! I replaced the check valves as they were weak & not holding a vaccum but the big problemwas that the vaccum cap that I plugged the 4x4 system with after installing the Posi-lok went missing & that is where the vaccum was bleeding offon acceleration which is when the a/c doors wouldswitch. The a/c is way colder now because I think that it was not having enoughvaccum to work all of the doors involved when the a/c is on. Now I hear the doors all snap shut which I never heard before, even before disconnecting the vaccum for the 4x4 posi-lok conversion.
[8D]
Old May 11, 2007 | 05:59 PM
shott8283's Avatar
shott8283
with it being a 4X4. i had the same problem.. took me a hell of a time tracking it down but i found the hard vacume lines comeing from the t-case to the front CAD/axle.. on a small section of the bends ,,these hard lines were rotted through.. you can get prebent ones from the dealer for pretty cheep.. i think less the 50 bones
Old May 11, 2007 | 06:32 PM
73scoutII's Avatar
73scoutII
I capped the vac off for the 4x4 system at the "T" that goes to the a/c & 4x4 so that there is no vaccum in the lines at all. Since I removed the cad & do not use the system I figured there was no reason to have vaccum in the lines at all but it is nice to know that the lines are not that expensive ;-)
Old May 11, 2007 | 07:34 PM
82lowe36id's Avatar
82lowe36id
There is a vaccum line under the battery. Sometimes acid will leak down on it and cuase a leak. Check it out.
Old May 11, 2007 | 07:46 PM
73scoutII's Avatar
73scoutII
Under the battery? what the hell does that one go to?
Old May 11, 2007 | 08:19 PM
dodgeram98's Avatar
dodgeram98
It's for the cruise control.
