98 ram 1500 need code info
Old May 9, 2007 | 12:56 AM
stovepipe's Avatar
stovepipe
Default 98 ram 1500 need code info
my 98 ram 1500 check engine light came on. ihad it checked at mylocal auto parts store. PO720 speed circuit sensor malfunction. where is this sensor ? and where is the best place to get it.
Old May 9, 2007 | 01:03 AM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: 98 ram 1500 need code info
The speedo sensor is on the transmission overdrive unit and the ABS sensor is the top of the rear diff.
Old May 9, 2007 | 11:44 PM
stovepipe's Avatar
stovepipe
so i guess i need to tell the dealer i need the one for the transmission right ?
Old May 9, 2007 | 11:52 PM
Sinister's Avatar
Sinister
yes, unless your parkbrake and ABS light are on also.. then its the one on the rear diff.
Old May 11, 2007 | 12:57 AM
stovepipe's Avatar
stovepipe
thanks for the help guys. i went to the dealer and got the speed sensor for the transmission today. it was priced better than i thought @ $22.00. unhooked the battery and putthe new sensoron hooked the battery back up drove it about 10 miles ITS FIXED THANKS.
