Truck Spooked
Old May 14, 2007 | 12:46 PM
99blueram's Avatar
99blueram
Default Truck Spooked
Hello everyone, Well got a issue that i hope you all can help with. Have a 2000 4 wd 5.2 that has a brake and abs light come on with no real noticable problems. Also the speedo will not operate until it shifts into 2nd gear. I will get more info as i can. [:@]
Old May 14, 2007 | 03:07 PM
etyler_Atlanta's Avatar
etyler_Atlanta
Default RE: Truck Spooked
same problem here.
Replace your rear speed sensor, top of the differential.
Good Luck !!
Old May 15, 2007 | 01:26 AM
99blueram's Avatar
99blueram
Thanks Etyler, I will go and get sensor. Thanks for the fast info.
Old May 15, 2007 | 01:28 AM
rollerstud98's Avatar
rollerstud98
yeah i had the same problem and that was the fix, hopefully it works out for you
