catalytic converter problems
Old Jun 1, 2007 | 04:17 PM
2001dodgeram1500's Avatar
2001dodgeram1500
Default RE: catalytic converter problems
but, how do you gut them ?
because mine is clogged right now and i either need to gut the cat
or get a new one, right now i dont have the money for a new one
Old Jun 1, 2007 | 06:46 PM
cify's Avatar
cify
Cut the pipe right after your cat and push it to the side, then take a crow bar or something straight and pretty solid and shove it in your cat over and over. Start your car and rev it a few times so that the ehxaust goes through it and throws all the junk inside your cat out. Repeat this as many times as needed till you have no more "honeycomb" inside your cat. Pretty much making it a hollow tube. then re-weld the pipes back together. This is illegal. but does give your car a nice sound
If you cant weld it i've heard of people using a clamp to get the pipes back together, but never tried it. Anyone else tried the clamp way?
Old Jun 2, 2007 | 02:29 AM
CALVIN305's Avatar
CALVIN305
i have the same "rattle" and am getting 8-9mpg. i was wondering if i could just cut the cat out and put a replament piece pipe in its place with clamps?
Old Jun 2, 2007 | 06:41 AM
cify's Avatar
cify
If the cat really is the problem then you need to fix it asap. Either get another cat, High Flow cat, or gut the one you have( illegal ). If you leave it for awhile all the junk inside of it will go back into the muffler and clog that too.
Old Jun 2, 2007 | 04:43 PM
RPRacing's Avatar
RPRacing
yeah, i think its time for me to do the same. I have that rattle, and i have ****ty mileage (i do have a v10, but still. 10mpg is about all it'll do)
Old Jun 2, 2007 | 06:08 PM
2001dodgeram1500
well i gutted it today ,and the rattle is gone but,the power is still not there.
i didn't have it welded back together so i know it should have more power
because there is no way for it too be restricted.
and next week sometime i am gonna buy a flowmaster or magnaflow and throw that on there.
i'll weld it then and i know it is illegal but when you got no money cause they hike the gas prices up to 3.60 a gallon
you do what you gotta do to get your vehicle running.
Old Jun 2, 2007 | 08:48 PM
cify's Avatar
cify
How does it sound now? Much louder or not much difference? It may be your muffler is clogged with the stsuffinside the cat.
Old Jun 3, 2007 | 02:29 AM
2001dodgeram1500
it is really loud right now because i have not hooked it back to the muffler so i cant blame the muffler.
i think i have a weak fuel pump it cuts out every now and then. i will have to check the
pressure next time it does this.
pressure should be a constant 49 p.s.i. correct
the engine is a 5.2 liter V8 (318)
Old Jun 3, 2007 | 04:17 AM
Ram_Sport's Avatar
Ram_Sport
love the laws that dont exist here about the cat sounds like a hot rod now woooooooohoooooo *honks dixieland horn*
Old Jun 3, 2007 | 06:13 PM
2001dodgeram1500
we dont have emissions test in nebraska unless you move here from out of state
then they doa test on the vehicle.
