will 20s off a 2006 fit my 94?
Old May 20, 2007 | 08:17 PM
Truck Ram ROD's Avatar
Truck Ram ROD
Default will 20s off a 2006 fit my 94?
i have a 94 with pollished alluminum rims 16s and i was lookin for a set of 20s of the 2006 rams not the flower style but the 5 spoke alluminums is the bolt pattern different or the same and does anyone know where i can get some if they will fit
thanks for your help
Old May 20, 2007 | 09:27 PM
shott8283's Avatar
shott8283
Default RE: will 20s off a 2006 fit my 94?
no.. IIRC they changed the bolt pattern in 06 03 to 05 is the same
Old May 20, 2007 | 11:42 PM
spaz_22's Avatar
spaz_22
they might have changed the bolt pattern in 06 becuase that's when they redid the suspension...hum....look up what the bolt pattern for an 06 is...if it's 5 x 5.5 or 5 x 139.7mm then it's the same as yours
Old May 21, 2007 | 12:01 AM
Dodge ram it's Avatar
Dodge ram it
Ive seen a ton of the ram's his year around here that have the factory 20's on them... But the bolt pattern of a 06 Ram 1/2 ton with the 20 is 5-139 per what Tire Rack says..... So dunno if that helps.
Old May 21, 2007 | 12:42 AM
spaz_22's Avatar
spaz_22
if it is 5 x 139 then it won't fit, they went to a slightly smaller bolt pattern then...you could put those 06 20's on a 97 and up ford though...maybe not cuz the hub may be too big....anyways, if tire rack is right and the bolt pattern is 5x139 and not 5x139.7 then i'm sorry they won't fit
Old May 21, 2007 | 06:38 PM
05SilverHemi's Avatar
05SilverHemi
There is a guy over on Dodge Talk.com that has a 98 1/2 ton with a set of 07 Rims on it. I do not remember his screen name but it is a white club cab with a custom front bumper. He is from Martha's Vineyard off the coast of Mass.
When I saw a post with the pic I contacted him. He bought them and bolted them right on without any problems.
Old May 21, 2007 | 06:49 PM
05SilverHemi
Did a quick search and found him over on Dodge Talk. It will not let me put the entire url in without editting it.
Old May 21, 2007 | 09:33 PM
shott8283's Avatar
shott8283
if you wish to exchange information about other dodge forums, you need to either use PM or other methods,,
its is not allowed to be linking for other competing dodge forums.. sorry
Old May 21, 2007 | 11:57 PM
05SilverHemi
I guess I didnt realize that I signed a non compete agreement when I registered with this site.
At any rate... go over to Dodge Talk.com and do a search for user name TheGTKid. He is the one running those rims on his 98 1500. I am sure he wont mind helping you out.
Old May 22, 2007 | 11:29 AM
Truck Ram ROD
about the 20s off the 03 -05 i heard that they get pitted from the stones that hit them i haven't seen that myself but thats what i hear is it true
thanks guys
