Hypertech vs Stage 1 Jet Power module
Old May 20, 2007 | 11:15 PM
ZFish85's Avatar
ZFish85
Default Hypertech vs Stage 1 Jet Power module
2001 Dodge Ram 5.9.......Debating on Hypertech or Stage 1 Jet Power Chip......anyone have any advice....Pro's Con's........Which one is better over all.....Let me know I want to purchase very soon
Thanks a Bunch!!
Old May 20, 2007 | 11:21 PM
dsertdog56's Avatar
dsertdog56
Default RE: Hypertech vs Stage 1 Jet Power module
Jet chip....paper weight.
Hyeprtech works good on a stock ram, but IMO the Superchips works best with mild mods.
If you're planning on doing a bunch of mods, I'd refrain from buying either and consider a custom reflash once you've done your work.
Old May 20, 2007 | 11:28 PM
Bigschwerm's Avatar
Bigschwerm
deff. stay away from the jet chip...
Old May 20, 2007 | 11:39 PM
bcdalton's Avatar
bcdalton
I'm thinking about purchasing the Hypertech programmer as well, but I'm concerned about pinging issues with mods as mentioned by other members. Would like extra power for towing. Considered a custom reflash, but I heard it is not recommended for heavy towing. Everything I've heard regarding the jet chip has been negative.
Old May 21, 2007 | 12:48 AM
Off_Road_Teacher's Avatar
Off_Road_Teacher
ORIGINAL: bcdalton
Ihad some pinging issues when i installed my hypertech, but once i switched to some autolite 3923 plugs it was gone. That was about a year ago and i have not had the pinging since.
Old May 21, 2007 | 01:19 AM
dhvaughan's Avatar
dhvaughan
after putting a hypertech (set for 87) on my 01 it pinged bad. 3923 did not help. 91/93 octane stopped the ping. fixing plenum and replacing timing chain allowed me to go back to 87 octane and no ping. i don't know if it was the plenum or the chain or both.
Old May 21, 2007 | 01:58 AM
Sirhilton17's Avatar
Sirhilton17
I got the hypertech on mine, on the 93 octane setting, I run 87 and never had a pinging problem.
It made a definate power increase, but i dont know if it was worth the price.
Old May 21, 2007 | 03:23 AM
jktrepin's Avatar
jktrepin
I want a hypertech also.... i just dont want the pinging also.
Old May 21, 2007 | 04:48 AM
Ramman18's Avatar
Ramman18
I have the hypertech and it pinged really bad off the get go with just a little throttle. Then I switched to 89 and it was a lot better but I hated running 89 when you're supposed to use 87. So I heard it may be a bad pcv valve and stuck a new mopar one in and trashed the fram crapper and now ping is gone with 89 and about half there with 87. The ppIII definately made a difference on the highway and mileage increased about 1mpg. Plus I adjusted for the bigger tires which corrected my gauges.
Heard nothing good about jet chips.
Old May 21, 2007 | 09:52 AM
2 Marks's Avatar
2 Marks
Hypertec 87 has done what I wanted. No pinging on 87 with 87; increase in MPG and significantly less shifting while towing. It was the first mod I did so I know it worked.
As for 87 setting versus 91/93, well you need to decide where you need the power. Looking at the dyno chart for my 2001, 87 produces more torq and HP than 91/93 in the lower bands... say until you hit 2750 or 3000 RPMs. I stayed with 87 since I tow a trailer and never get to those RPMs unless I am pilling a big hill.
I am sure the SuperChips programmer is a good product as well but I have no experiemnce with it.
