softer shock ?
Old May 22, 2007 | 12:04 AM
whiteram00's Avatar
whiteram00
Default softer shock ?
which shock is the softest for these 2nd gen rams the monroe reflex or the sensa trac shock,orwhat other brand is a good soft shock thats not to high on price,looking to spend about 40 to 45 on each shock
Old May 22, 2007 | 12:41 AM
Aubrey's Avatar
Aubrey
Default RE: softer shock ?
I had a set of Trailmaster SSVs and really liked them. I've never bought a $40 shock though. Well, on my Falcon but that's a little different.
Old May 22, 2007 | 01:35 PM
lv360ram's Avatar
lv360ram
I am **** when it comes to shocks. [:-] Ibought Gabriel shocks, the Monroe standard, Sensatrac, and Reflex. And I tried them all on my truck and even combinations front and rear. Needless to say I did alot of wrenching. The best combo was Sensatrac on the front and standard on the back.Anything other than standard on the back the ride will be harsh.Gas magnum is stiffer than standard, sensatrac is stiffer than gas magnum, and reflex is stiffer than sensatrac.
Take a gas magnum and a reflex, one in each hand, set them on the floor and push on them at the same time and you will feel the stiffness.
In general, more expensive = more stiffer.
Just my experience, results may very and it's all relative.
Old May 22, 2007 | 08:52 PM
BeachCrawler's Avatar
BeachCrawler
I have sensatrac and I am pleased.
Old May 27, 2007 | 11:58 PM
whiteram00's Avatar
whiteram00
what would be a good choice of a soft shock, i need some soft ones bad asap
Old May 28, 2007 | 12:26 AM
lv360ram's Avatar
lv360ram
monroe matic plus
Monroe E-Catalog
Passenger Cars and Light Trucks - Ride ControlSection
DODGE
2000 - Pickup ( 1/2 Ton) 4 W.D. (Ram 1500 & W Models)
1994 - 2001 1500 Series
Need help deciding which of Monroe's product lines is right for the way you use your vehicle?
Highlighted part numbers indicate premium products.
37104
SENSA-TRAC® TRUCK SHOCK ABSORBERS
37104
911104
REFLEX™ TRUCK SHOCK ABSORBERS
911104
34778
GAS-MAGNUM® SHOCK
34778
32279
MONRO-MATIC PLUS® SHOCK
32279
37105
37105
For Towing and Hauling
f:P
58615
SENSA-TRAC® LOAD ADJUSTING SHOCK ABSORBERS
58615
f:P
911103
911103
34777
GAS-MAGNUM® SHOCK
34777
32278
32278
f:P
This part number is pair packed/priced.
