I need to buy an intake TODAY!!! HELP!!!
Old May 25, 2007 | 04:37 PM
mikerados21's Avatar
mikerados21
Default I need to buy an intake TODAY!!! HELP!!!
Well today is my 17th birthday and i got some money saved up ($350)anywayz i need to get a better intake on my dodge like an M1... But i want an intake that i can just run my 53mm Throttle Body off it. Im getting confused with the whole 2 and 4bbl. making it Carburated and whatever. What intake can i run with a stock throttle body cuz my 53mm fits on my stock intake. THNX!!!!
Old May 25, 2007 | 04:47 PM
dnfd737's Avatar
dnfd737
Default RE: I need to buy an intake TODAY!!! HELP!!!
your tb will go on to the 2bbl m1 if you have a/c you will need to fab a mount for it from what I have read.
Old May 25, 2007 | 06:14 PM
RM_Indy's Avatar
RM_Indy
Happy BDay!
Expect to pay about 500-525 with the install kit (spacers/bolts for fuel rails/accessorys)and gaskets unless you buy used.
M1/2BBL needed no modifications when Iadded the 52mmfastman.53mm may need to be opened slightly. When I moved up to the 55mm Hughes billet tb I had to open up the M1 a fiar bit and match the gasket to the larger tb bores. 55mm biggest you can run on a 2BBL.
If your building a monster motor go the 4BBL, if its mild to average build go with the M1/2BBL
If you buy a carb version M1 you will have no injector bosses so will have to run a carb and replumb the fuel system which is not advisable. Better tune/power with fi.
Old May 25, 2007 | 06:16 PM
mopowar's Avatar
mopowar
If you buy the kit, the only fabbing of any kind you have to do is to extend the iat sensor wiring about 6" with the butt splices and wire provided.
Old May 26, 2007 | 02:01 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: mikerados21
sounds like you have an indy or sst, lets see some pics.
+1 on indys post.
Old May 27, 2007 | 02:23 AM
mikerados21
Do you have to have a 5.9 in order to get a 2bbl M1 if you do what can i get for my 5.2??? Its not a ss/t or a indy... sorry!!!
Old May 27, 2007 | 08:13 AM
dnfd737's Avatar
dnfd737
I just looked in the mp catalog they make a 2bbl intake that works with a/c it fits both 5.2 and 5.9 it is a direct replacement for the stock setup and all of the stuff will transfer from the stock setup to the m-1. I did read some where you may need to extend some wires for the sensor on the back of the tb
