should my fuel look like this?!?!?!?
Old May 27, 2007 | 12:45 AM
shott8283's Avatar
shott8283
Default should my fuel look like this?!?!?!?
this came out of my truck today.. after filling up last night before going to work.. bought 22 gallons of 93 ultra for 3.12 a gallon.. i thought it was a sale or a great deal b/c normally 93 is 3.40 around here.. 2 miles away from the gas station i drop 3 cylinders from misfires( 5,7,8, ironically the first 3 that get fuel first) finally got it to work.. thought it was an ignition problem.. but i ruled that out.. i ended up getting it home and in the shop... i took a sample out of my fuel cooler.. and this is what it looked like... i was sooo pissed i took the wifes jeep to that gas station and found out that the pumps are out of order and NYS scales and weights commision was there investigating the tanks... i guess a few other people complained.. the supplier of the fuel will be contacting me shortly..
soo... need some input..
i have the injectors. tb. and fuel rail off to get cleaned out tomorow,, (gotta work tonight) .. what do you guys think.. should i pump the rest out and drop the tank and try to clean it out.. or should i just pump as much out as possible and refill it with good fuel and try to run it? lets hope nothing got damaged by running a 5 cylinder motor
Old May 27, 2007 | 03:04 AM
nim81's Avatar
nim81
Default RE: should my fuel look like this?!?!?!?
i would say suck it dry and clean that thing out, you dont want to have this happen again as soon as you fire it up again.
Old May 27, 2007 | 10:04 AM
turkeyhunter1962's Avatar
turkeyhunter1962
Best option is always to get rid of as much of the bad gas as possible. If the fuel company is getting in contact with you discuss your cost of the entire fuel system flush including the fuel tank. You might also think about any possible damage to your fuel pump from this so-called fuel.
Like you, I'd be extremely pissed had this hapened to me. Good luck in getting this resolved.
Old May 27, 2007 | 04:29 PM
JarheadX's Avatar
JarheadX
man, i live in rochester! thats close to me, where did u get it from? I was using HESS and then i swithced to citgo and my gas milage is going up.. i hate hess
Old May 27, 2007 | 06:08 PM
shott8283's Avatar
shott8283
yellow goose/sunoco in Leroy .. on rt. 5
i know dude.. i live like 20 mins from you.. i can throw the rock and hit the 490
Old May 28, 2007 | 04:32 PM
topsites's Avatar
topsites
No, I don't think your fuel should look like that.
SUL should be either clear, or perhaps a light blue or light purple tint, like so:
Yes, that glass jar is full of Amoco 93 octane Super Unleaded, which in and of itself is clear like water.
Thou it came out of a 5 gallon can to which I had added 8 ounces of Sunoco 110 octane leaded (for offroad applications only).
Now that's some spirited stuff lol, but technically super unleaded should have NO tint at all, no discoloration.
Old May 30, 2007 | 07:00 PM
catthead's Avatar
catthead
that sucks man. at least you caught it early. that could definitely ruin your fuel system.
