Tire Size limit for half ton rears?
Old May 29, 2007 | 01:35 AM
Moparkid032's Avatar
Moparkid032
Default Tire Size limit for half ton rears?
Ok I am just curious how big would you set the limit for tire size on these half ton rears and drive train??just curious..cause i want to eventualy go bigger but dont want my whole drive train blowin apart on me...thanks
Old May 29, 2007 | 01:59 AM
royiii's Avatar
royiii
Default RE: Tire Size limit for half ton rears?
Bigger the lift the bigger the tires. With proper maintance your 1/2 ton running gear shouldn't have any problems
Old May 29, 2007 | 03:03 AM
spaz_22's Avatar
spaz_22
the biggest most people and i would recommend for the stock 1/2 ton drivetrain is 35's for wheeling. if you got 38's that's alot of wear and tear and it's very very likely you'll blow an axle pretty quick
Old May 29, 2007 | 04:20 AM
G0tMudd's Avatar
G0tMudd
If u have the right gearing u should be totaly fine. I have stock gearing and running 35's and i wheel my truck hard. I have never broken a axel, but i have stripped a gear.. I'm going in for new gears soon with the right ratio. Plan on spending 1,500 on gears. Gears give back gas millage, power, dosent strain the engine etc.
Old May 29, 2007 | 04:47 PM
tdmopar59's Avatar
tdmopar59
yea you definitely wanna change gears with tires they go hand in hand otherwise its gonna cost u money in the end
Old May 30, 2007 | 12:48 AM
Moparkid032
so if i gear my truck right than tire size wont be a issue than?
Old May 30, 2007 | 01:12 AM
G0tMudd's Avatar
G0tMudd
U should be fine, now if your goin to stick liek 44's on and plain on wheeling hardcore u might wanna upgrade your axels :P
Old May 30, 2007 | 02:42 AM
Socha_62's Avatar
Socha_62
Your not gonna blow a 9.25 apart with any ease, but yeah its possible. The crapiest part about them is that its c-clip, but you could still run probably 40's on it.
