convert dually to single wheels
Old May 31, 2007 | 03:32 AM
battering ram's Avatar
battering ram
Default convert dually to single wheels
I just purchased my second dodge diesel truck a 01 dually and I was wondering if it is possible within the realm of economics to convert it to a four wheeled unit I understand the wheels/rims and the box as well as the front bolt on hubs need to be replaced anything else? The truck is a 4x4 and has rear disk brakes. If any body out there has seen or heard of this being done I would appreciate the information.
regards,
Josiah
ktown bc
97 dodge 5.9 cut throttle plate timing adj.
01 dually 24 valve
equipment haulers as kickers
Old May 31, 2007 | 04:53 AM
rollerstud98's Avatar
rollerstud98
Default RE: convert dually to single wheels
just get a massive wheel and tire combo on the back, super wide
Old Jan 20, 2009 | 07:08 AM
purplhrt91's Avatar
purplhrt91
But where can you find the massive wheel & tire combo. I've seen a dually with that and it looked awesome.
Old Jan 20, 2009 | 08:33 AM
xskylinedx's Avatar
xskylinedx
My uncle converted a single 14 bolt gm axle to dual and I thought all he did was get longer
studs along with dually wheels. So maybe thats all you have to swap; shorter studs and
standard wheels. With regards to the extended wheel well, I have no idea how those are
attached from the factory, i've never crawled around one.
Old Jan 20, 2009 | 09:19 AM
dodge15004x45.9's Avatar
dodge15004x45.9
trade axles?
Old Jan 20, 2009 | 02:46 PM
txredneckmedic's Avatar
txredneckmedic
you could possibly run a super single from a semi
