No Power- Check Eng. Lite
Old May 31, 2007 | 03:29 PM
BostonRamGuy's Avatar
BostonRamGuy
Default No Power- Check Eng. Lite
Hi Guys, So on the highway in my 98 Ram 4x4 5.2L V8, I would get above 50, the eng. would make some straining noises like it had no power, then the check eng lite would go on. When I got off the highway on the back roads (30mph) the light would shut off and the truck would run fine. Took it into the shop, he said the only code that came up was a misfire and everything else checks out. He is doing a tune up overall right now. Has anyone else delt with somethinglike this? Thanks-
Old May 31, 2007 | 04:16 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: No Power- Check Eng. Lite
I bet your cat is plugged. Have that pressure checked before replacing any ignition component.
Old Jun 1, 2007 | 09:07 PM
BostonRamGuy
Thanks Wand, Got the truck back today, seems to be running a lot better- I have yet to open it up on the highway to see overall.
