trany cooler line
Old May 31, 2007 | 05:40 PM
turbo8's Avatar
turbo8
Default trany cooler line
my lower line is broken, the rubber hose with the quick disconnect. where canI get a replacment?
the dodge parts guy gave me a quote for $70, part # 52028769ae i dont know if thats right though
thanks for any help
Old May 31, 2007 | 06:36 PM
dhvaughan's Avatar
dhvaughan
Default RE: trany cooler line
you could replace the fancy factory hose with 3/8" auto trans hose and clamps. if i remember right the lower hose is the hot line, and it has a crimped fitting on one end and quick connect on the other. when i added a transmission cooler i just cut all that stuff off and used hose. a dremel tool works good to cut the crimp apart and a tubing cutter will cut the metal line. trans hose is about $1 per foot.
Old May 31, 2007 | 06:43 PM
turbo8's Avatar
turbo8
thats what i sorta did, to try to temporarly fix it, but it still leaks where the quick connect used to be.
i would just like the factory hose, but that price the guy quoted me didnt seem right
Old May 31, 2007 | 06:57 PM
dhvaughan's Avatar
dhvaughan
double clamp it.
Old May 31, 2007 | 06:58 PM
turbo8's Avatar
turbo8
good idea, :-)
Old May 31, 2007 | 08:04 PM
lv360ram's Avatar
lv360ram
I had the same problem with 2 different Dakotas. Of course I only needed the 10" long hose part but had to order the entireassembly with hardline back to the trans. I paid around $80. It sure was an easy fix with the right parts.
Old May 31, 2007 | 09:06 PM
superfluous's Avatar
superfluous
You can use 3/8" hose barb fittings for extra assurance that the clamps won't come off.
Old May 31, 2007 | 09:12 PM
WayneC's Avatar
WayneC
If its just a hole in the line, go to the hardware or home center and get a flare fitting for each side of the tube and repair it right. Solid connections and won't leak unless you do it wrong. Or you could do the same with a compression fitting on each side.
