Stutters and backfires through TB
Old Jun 2, 2007 | 08:33 PM
Bigtaz43's Avatar
Bigtaz43
Default Stutters and backfires through TB
Hello everyone.
I am new to the forum and am having problems with my 94 1500 with a 5.2 V8. I recently replaced the cap, rotor, plugs, wires, O2 sensor and EGR valve. It would idle rough but that has gone away. The main problem that I am having is that when I accelerate it will stutter and sometimes sounds like it is popping back through the TB. When I am at a steady speed above 40 mph it surges, like it is bucking. No check engine light comes on. I took it in to a garage to see if they could find out what wasing causing the problem and all they said was it was low on tranny fluid and it was putting out a code for tranny high temp. If anyone has any idea what this could be I would really appreciate it. Thanks
Old Jun 2, 2007 | 08:50 PM
WayneC's Avatar
WayneC
Default RE: Stutters and backfires through TB
Might be the crank sensor. Just guessing though without any codes.
Old Jun 2, 2007 | 09:20 PM
Rammer1500's Avatar
Rammer1500
Your engine is very particular when it comes to the routing, and shielding of the plug wires....
Go here, it may help you [sm=confused06.gif]
http://autorepair.about.com/cs/faqs/l/bl654h.htm
Old Jun 3, 2007 | 02:44 AM
2001dodgeram1500's Avatar
2001dodgeram1500
my truck does the same thing
i have to check the routing of the wires
thanks guys for the info
Old Jun 3, 2007 | 02:03 PM
Bigtaz43's Avatar
Bigtaz43
Thanks everyone for the info. I will check my wire routing and see if that helps. If anyone has anymore ideas I would appreciate it.
Old Jun 5, 2007 | 01:11 PM
keith1965's Avatar
keith1965
SSDD!I have a 95 ram1500 4x4 5.2 and is doing the same thing.I also replaced all that you did,now im putting a trans kit in it today to see if that cures the bucking,also you need to check your fuel pressure.it should be 60 to 70 psi,any lower then i would change the fuel pump because the filter is made on the pump in the tank,lmao.But my truck is not backfiring like yours is!Good luck with yours and this will be my last dodge because of all the problems!
Old Jun 6, 2007 | 04:07 PM
2001dodgeram1500
wow i thought it says fuel pressure should be about 49 psi + or - 5 psi
hmmmm... well yours could be a completly different system mines a 2001 ram
your's is a 95. Anyone else know for sure what it is supposed to be?
Old Jun 8, 2007 | 12:21 PM
trucklover's Avatar
trucklover
Did you reset the computer?
Old Jun 8, 2007 | 12:36 PM
Bigschwerm's Avatar
Bigschwerm
^^^ unhook positve batt cable...turn key to run posistion for 30 seconds to discharge the capacitors in the pcm....turn key off then hook pos. batt. back up....
