Fuel Leak
Old Jun 3, 2007 | 11:23 AM
Fluxghost's Avatar
Fluxghost
Default Fuel Leak
Hi folks,
I am new to the forum, please forgive any mistakes.
I have a 1998 2500 4x4 12 valve Cummins and it is leaking fuel somewhere behind or underneath the fuel filter mount. I hoped that it was just a faulty o-ring but no such luck. I can tell that the block and the other components in this area of the engine are Very clean, butI can not find the leak. If anyone else has had this problem, please let me know what you had to do to fix it.
Thanks
Old Jun 3, 2007 | 12:24 PM
dhvaughan's Avatar
dhvaughan
Default RE: Fuel Leak
welcome.
you should repost over in the diesel sub-forum. the diesel guys may never see it over here.
navigate through the forum tree - Dodge Forums - Dodge Trucks - Dodge Ram - Dodge Cummins
you might also check out dieseltruckresources.com very active. a little dictatorial.
good luck.
