Well tonight sucked! Blew myraditator hose. Temperature gauge hit the red line may have driven a mile or two before I noticed. Temporailiy fixed it but I need a new hose. No air bubbles in the radiator. Do I need to be worried and what else do I need to check.
Best thing to do is fix it, fill it, say a prayer and start it. Watch the gauges (water and oil) and the tailpipe for steam. Good luck, I hope everything holds.
thanks i hope so to. it seemed ok after ib had sorted the hose and filled it back up. sounded ok will check it again tomorrow. just didnt know if i should be cheching anythibg else.
