does my truck....
Old Sep 23, 2004 | 07:41 PM
james ram's Avatar
james ram
Default does my truck....
have an LSD?
how can i tell? would there be a code in the VIN or anything? i looked for tags on the diff cover and axle but i didnt find anything on the rear.... there was a DANA stamp on the front and a tag with a bunch of numbers but over the years, it got hard to read.
99 Ram Sport 4x4 5.2
Old Sep 23, 2004 | 07:57 PM
GMsucks's Avatar
GMsucks
Default RE: does my truck....
Call your local parts dept with the VIN and askif it is the open or limited slip rear.(If they get ****ty, tell 'em you want to know so you get the right parts when you order them from them.BS 'em a little if you have to.)
The axle codes off of the front will do nothing for you as the fronts NEVER have limited slip.
Old Sep 23, 2004 | 08:06 PM
james ram's Avatar
james ram
ORIGINAL: GMsucks
not a bad idea....
i knew the front was open but it seemed strange to me that the front cover would have stampings and the rear would be blank...
Old Sep 23, 2004 | 08:38 PM
adamsredlines's Avatar
adamsredlines
I know on my '04, there is a plug going into the top of the "pumpkin" that controls the LSD....Yours may be different, but a plug going into the top is a good clue.
Old Sep 24, 2004 | 04:48 AM
dodgemech's Avatar
dodgemech
ORIGINAL: adamsredlines
HUH??? No, the plug on top of your differential has nothing to do with limited slip, that is the wheel speed sensor for the ABS. The only vehicle DCX builds with anything going into the diff to control locker operation is the Wrangler with air lockers.
Old Sep 27, 2004 | 03:11 AM
94ram4x4 5.9's Avatar
94ram4x4 5.9
Stomp on it when you are taking off at a corner, WHERE YOU CAN SAFELY, see if the tire inside the turn spins...and there you go. If it does then you got LSD, if not you have anti-slip.
