Putting a double din radio in a 2nd gen Ram
Old Jun 14, 2007 | 10:18 AM
n1rigger9's Avatar
n1rigger9
Default RE: Putting a double din radio in a 2nd gen Ram
Thanks,
Actually, in this case Rigger stands for Parachute Rigger. And in todays military, that is an even more demanding proffesion. LOL
Old Jun 14, 2007 | 10:45 AM
n1rigger9's Avatar
n1rigger9
BTW, my next project is the install a Ranger RCI-2950. My plan is to purchase an extra kick panel. The part of the lower dash right below the stereo and cup holder. Then I am going to cut a hole in it large enough to put in the radio at the optimum viewing angle. Then fill and paint the outer edges of the hole to make it look like it came that way. That way I will be able to have the radio installed in the dash like the stereo is. I will then purchase the neccesary length of coax (in the propper 3 foot increments for the lowest possible SWR reading) to route it through a rubber gromet in the firewall, under the truck and out to the area I am going to mount the anntena. Which I havnt decided on which one to get yet. I am looking for an anntena that is a 102 inch steel whip that is tuned to work in the 10 and 11 meter freq range. More than likely I will attatch it to a quick release on a ball mount somwhere on the side of the truck bed. Or actually consideringthe inside of the front of the bedjust below the cab rear window.I am in Iraq right now so this project will have to wait until the August time frame, but I will make sure I post pictures of it when I am finished.
