Side moldings
Does anyone know where I can get the black side molding trim that runs down the side of the truck. THe black trims is starting to peel and I wanted to know where I could get some new molding to replace it with.
well dodge for one and also when i was at a paint shop one day they had alittle panel on the wall that had all the diff moldings so i would assume they coul,d order it mabe by the foot and just cut it to fit
LMC doesn't carry the 2nd gen black moldings from what I've seen yet. I found a place that sells the Dodge stuff in bulk rolls, but that won't really work since the ends are tapered and I don't think you could cut the compound angles and make it look good.
I saw an unsed set on ebay about a month ago and the whole set went for around $200.00, and I believe the seller said he had over $300.00 in the modlings from the dealer. After hearing that, I started combing the junkyards for it. You can always use new 3M VHB tape on older moldings as long as you can find ones in decent shape. So far i have struck out though FWIW.
I found them at a body shop that is apart of the dealership I work at. I'm getting the side modlings for the whole drivers side for 120. I decided to redo the embelems with 3rd gen ones too
