2" lift
Old Jun 14, 2007 | 07:09 PM
sbrunn9's Avatar
sbrunn9
Default 2" lift
I just found this lift on ebay
http://tinyurl.com/2kjzad
It says that it doesn't come with shocks or accesories and that those options are listed below. But I wouldn't need new shocks or a steering stabilizer would I? Is it a good idea to get them or does it not matter?
Old Jun 14, 2007 | 07:10 PM
sbrunn9's Avatar
sbrunn9
Default RE: 2" lift
Sorry about the link it's not a link. But that is the site if you paste it into your browser window.
Old Jun 14, 2007 | 07:56 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: 2" lift
That's the same lift I started with. It is Skyjacker part number D201k, and is the same price from Summit.
If you don't wheel a lot, then no, you do not need new shocks. Stock shocks would work fine with 2" for daily driver street/highway use in my opinion. No need for a new steering stabilizer unless yours is bad,
Old Jun 15, 2007 | 01:09 AM
sbrunn9's Avatar
sbrunn9
Default RE: 2" lift
Thanks that was the answer I was looking for.
Old Jun 15, 2007 | 05:34 AM
sbrunn9's Avatar
sbrunn9
Default RE: 2" lift
If I had this lift on my truck and bought tires and kept the stock rims would 315's fit? Would they be close and I could use a 1/8 spacer or something to fix the rubbing? Or would I have to go down to the 295's.
Old Jun 15, 2007 | 05:41 AM
cify's Avatar
cify
Default RE: 2" lift
do you have the sport or off-road package with the 3inch factory lift?
Old Jun 15, 2007 | 09:31 AM
flintspirit's Avatar
flintspirit
Default RE: 2" lift
I bought my 96 truck used and it had sport 4x4 offroad stickers on the back so is mine the sport package? How can you tell? I put 33's on15 inch rims andI have no rubbing issueson or off road.
Old Jun 15, 2007 | 02:29 PM
sbrunn9's Avatar
sbrunn9
Default RE: 2" lift
Mines the sport model without the offroad package. The offroad package came with different 5 spoke rims and hooks coming through recesses in the front bumper. I believe they also had posi.
Old Jun 15, 2007 | 03:54 PM
Silver_Dodge
Default RE: 2" lift
315's would be really pushing it on stock rim backspacing without rubbing the control arms. If you had some rims with less backspacing (like 4.75" or 4.5" instead of the stock 5.5"-6"), then you could probably run a 315 with out rub unless you liked to go off-road. I'd say go with a 295 or even test fit a 305 and see if that would work.
Old Jun 15, 2007 | 06:40 PM
cify's Avatar
cify
Default RE: 2" lift
Ya you would be very close. I have a 99 sport with 295's and whenI crank the wheel they rub. Just go to any tire shop and talk to them about it. (I went to a family owned place where they are honest) Some shops also will put the front tires on and check for clearence before finishing up the job.
