front end trouble
Old Jun 15, 2007 | 01:46 PM
96dodgeboy's Avatar
96dodgeboy
Default front end trouble
how hard is it to change front axle seals on 96 dodge ram 4x4 mine appear to be leaking but cant be that bad cause when i checked fluid it wasnt low
Old Jun 15, 2007 | 04:15 PM
catthead's Avatar
catthead
Default RE: front end trouble
What is giving yout he impression they are leaking? If they are in fact leaking you can check out this link here and it should help ya out some. Good luck.http://www.pavementsucks.com/tech/axleseal.php
Old Jun 15, 2007 | 08:07 PM
dhvaughan's Avatar
dhvaughan
if the axle bearings have ever been changed and put back with anti-seize, then its not too bad. if not, and the brgs are rusted into the knuckle, then its a pita, and you're likely to bust the brg during removal. if you can stand the leak, it might be easier and cheaper to add fluid.
Old Jun 16, 2007 | 02:01 PM
flintspirit's Avatar
flintspirit
mine has leaked for 4 years! just keep it checked. Kinda handy actually cuz it's self changing! lol
