fipk install help
Old Jun 17, 2007 | 08:48 PM
dobbie146's Avatar
dobbie146
Default fipk install help
I got my fipk the other day 1511-2, for my 99 sport 5.9.
I followed the insturctions but I do not have a evap canister or bracket on the right inner fender. It says i need to remove stock gromets and reuse hardware.
Anyone else ran into this??
[align=left] [/align]
Old Jun 17, 2007 | 09:01 PM
dnfd737's Avatar
dnfd737
Default RE: fipk install help
I have looked at the instructions and am clueless to your problem I would say email their tech help dept and ask them. sorry to not be of any help to you.
Old Jun 17, 2007 | 09:27 PM
dobbie146's Avatar
dobbie146
http://www.kandn.com/instructions/57-1511-2.pdf
step 7-10. I have a purge solenoid with one bolt to the inner fender..thats it.
Old Jun 18, 2007 | 01:29 AM
jram99's Avatar
jram99
The purge solenoid and evap canister are on the passenger side frame rail under the truck on the 99 sports. If you look just under the passenger door you will see it. You should just get what ever hardware you need and mount it. Jeff.
Old Jun 18, 2007 | 06:26 PM
dobbie146's Avatar
dobbie146
thanks..
i just called K&N and its not needed becuase it just relocates the canister so its out of the way for the filter
