supension
Old Jun 20, 2007 | 12:52 PM
nobletuckyram's Avatar
nobletuckyram
Default supension
sorry for the stupid ? new proud ram owner 01 1500 quad cab 4x4 360 stock for now. ? is this after putting new tires 265/75/16 people ask if i got it lifted. i dont know. i cant ask guy i bought it from he's in jail. it didn't seem tall when i bought it cause it had bald 245/75/16 on it. how is any easy way to know? thanks
Old Jun 20, 2007 | 01:28 PM
dusty_duster's Avatar
dusty_duster
Default RE: supension
I belive that 265s will fit with the stock 4x4 suspension.
rtmorrisjr's Avatar
rtmorrisjr
you probably didn't get a lift kit while changing tires (if im reading correctly) But you did go from a 245 to a 265. The tire size is about an inch or 2 different. so it migh apear to sit higher (and does) but not cause its lifted. But to check to see if its lifted, and probably not much or you would def. know, look at the front coil springs. on the top there would be (as long as the lift was just the leveling kit or like 3 inches) a rubber boot about 2-3 inches thick. That would mean it had a lift. I just bought some on ebay...heres the link http://cgi.ebay.com/ebaymotors/ws/eB...m=140127046171. If you see something like those you have a leveling kit. Hope this answers your question.
Old Jun 20, 2007 | 01:41 PM
zique's Avatar
zique
You can also check the rear leafs to see if you have blocks as well as the body mounts to see if it's a body lift. But I'm guessing it's not lifted, just the larger tires (I got the same question when I stuck 33's under mine when I had the stock susp.
Old Jun 20, 2007 | 02:45 PM
nobletuckyram
yeah, thanks guys i don't think it lifted. its justs the tires. just that it pretty much chevy ville round here and my truck is high as some with 2" lift. cant wait to show em up!
Old Jun 20, 2007 | 08:02 PM
dhvaughan's Avatar
dhvaughan
compare this to yours. my 01 non sport, non offroad has factory 3" blocks under the leaf springs and the rear fender wells sit 41" from the ground at the center of the tires. i think the front is about 39. i have about 1/2" sag on the drivers side. my tires are a little taller.
Old Jun 21, 2007 | 04:00 AM
spaz_22's Avatar
spaz_22
it's not lifted. 265/75/16's were a dealer option...my truck came with them stock. My truck was completely stock when i bought it...
