power loss troubleshooting
Old Jul 7, 2009 | 11:19 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by zman17
Removing the o2 sensor will only check the cat if it is badly clogged and hardly runs or won't run at all. It needs a backpressure test or atleast a thermal test. And since it's a 98, and the original cat as far as you know, it's bad or going bad. And you'll want to check the plenum also.
Agreed. Get the cat pressure tested.
Old Jul 7, 2009 | 11:27 AM
zman17's Avatar
zman17
Retired Moderator - RIP
There is still a vac problem that needs be addressed, but, you can just gut the cat to eliminate that prob. And replace it and a later date if your state does E tests.
