TRUCK WON'T START
Old Jun 24, 2007 | 08:41 PM
shrtrndjr's Avatar
shrtrndjr
Default TRUCK WON'T START
OK HOPEFULLY SOMEONE CAN HELP, IT ALL STARTED WHE TRUCK STARTED RUNNING ROUGH AND STALLING SO I CHECKED THE DTC'S AND FOUND THAT IT COULD BE CRANK SENSOR SO I REPLACED IT AND THEN IT WOULD CRANK BUT NOT TURN OVER, SO I WAS TOLD TO CHECK THE VOLTS ON THE TPS AND CAM SENSOR SO I CHECKED THE TPS ANDHAD 5 VOLTS THEN TRIED TO START IT NOW I GET NOTHING. ANY SUGGESTIONS WOULD GREATLY HELPFUL. THANKS
Old Jun 24, 2007 | 09:32 PM
XXL 1500's Avatar
XXL 1500
Default RE: TRUCK WON'T START
cap rotor wires spark plugs coil
IAC-idle air control on throttle body
defective TPS or CPS-even if new
year-make-model-engine?
Old Jun 25, 2007 | 07:45 PM
shrtrndjr's Avatar
shrtrndjr
ITS A 98 1500 4X4 5.2L 5 SPEED
Old Jun 25, 2007 | 08:32 PM
XXL 1500's Avatar
XXL 1500
could be plenum gasket is gone completely.
had one yesterday that set codes for being really rich mixture
and looked in throttle body , puddles of oil in there- plenum gasket.
the truck was having problems that it would not run when it got to running temperature.
could be that, or any of the things above^
Old Jun 25, 2007 | 08:44 PM
nim81's Avatar
nim81
same thing happened to me it was the pickup coil under the dist. cap.
