Reverse lights
Old Jun 27, 2007 | 01:00 AM
Truck Ram ROD's Avatar
Truck Ram ROD
Default Reverse lights
hey guys and gals i have a 94 1500 with a V6 with an autotranny and for the longest time the reverse lightshave not workedhave you heard of this? is it a common problem? and are there any tips for fixingthem and yes the bulbsand fuses are both goodi appreciate the help thanks in advance
Old Jun 27, 2007 | 02:26 AM
dhvaughan's Avatar
dhvaughan
Default RE: Reverse lights
when i first bought my truck the backup lights didn't work, but it was just a blown fuse.
visually check your wiring around the back of the truck and make sure nothing is broken or torn off. if ok, remove the bulb and check for presence of 12 volt while in reverse. if present, then you've got some kind of socket or bulb problem, might try spraying out with wd40. if no 12 volt, you'll have to trace your wiring back to where it comes from. should be a reverse light switch somewhere in/around the shifter/transmission linkage, which is likely broken.
Old Jun 27, 2007 | 02:38 AM
froesen's Avatar
froesen
the reverse/neutral switch are one and the same, 3-wire connector near the shifter linkage which can be removed with a wrench from the outside, mounted in the transmission.
