15" wheels on ram
Old Jun 28, 2007 | 01:17 AM
lucas3397's Avatar
lucas3397
Default 15" wheels on ram
It seems like I read somewhere that you cant put 15" wheels on a ram because of some certain caliper clearance or something. I'm not sure if it was for the 4x4 or 4x2, but does anyone know.....
Old Jun 28, 2007 | 02:46 AM
don_ripley's Avatar
don_ripley
Default RE: 15" wheels on ram
I have 15" rims on my 1995 1500 4x4, with 33x12.5 tires on it, no problems at all.
Old Jun 28, 2007 | 02:59 AM
echseman's Avatar
echseman
same here. it's close, but it clears just fine..
Old Jun 28, 2007 | 03:55 AM
spaz_22's Avatar
spaz_22
in 99 dodge changed to a dual piston caliper. So 15's will rub the caliper, you can get them to fit but you'll need to grind the caliper or replace with a single caliper setup
Old Jun 28, 2007 | 01:49 PM
zique's Avatar
zique
It also depends on if you have the sport package or not. I believe it is the sports (and probably off-road editions as well) they went with a larger diameter rotor.
Old Dec 22, 2007 | 08:46 PM
Joedodge63's Avatar
Joedodge63
Slightly off topic... will the dual piston calipers fit my 96 CTD4x4? I would like a brake upgrade. Now back on topic....anyone have 15 inch old style aluminum slots on their 2nd gen? I think that would look sweet! Post pics if ya have em!
Old Dec 23, 2007 | 07:41 AM
shott8283's Avatar
shott8283
the calipers probablly wont fit on your CTD as its a 3/4 or 1 ton pickup having dana 60 front axle.. and i think its different mounting system..
pretty sure the sports and non sports have the same rotor as it did not matter when i put new ones on my ram.
Old Aug 12, 2009 | 10:03 PM
AmericanPower's Avatar
AmericanPower
Thoses who have 15's on your Ram, do you have a bigger offset ??
I'm not worried about the caliper, but I don't think the tie-rod end will clear it.
95 1500 4x4
Old Aug 13, 2009 | 07:45 AM
audiomechanic's Avatar
audiomechanic
Mine is a 99 sport and I'm running 15" rims no problems.
Matter of fact, if the OP wants to buy my rims with the current tires on them, he can. I bought a set of stock steelies that I'm going to throw on the truck.
Old Aug 13, 2009 | 11:15 AM
Bob5151's Avatar
Bob5151
The Sport package is just an appearance thing, no difference in brakes.
