r/t manifold
Old Jun 28, 2007 | 09:34 PM
dobbie146's Avatar
dobbie146
Default r/t manifold
http://cgi.ebay.ca/DODGE-RAM-DAKOTA-...QQcmdZViewItem
has anyone heard anything about these??? im looking for something for my 360..
Thoughts.
adam
[align=left] [/align]
Old Jun 28, 2007 | 09:51 PM
Bigschwerm's Avatar
Bigschwerm
Default RE: r/t manifold
yes or you can do the same thing yourself all you need is a dremel and some time...
Old Jun 28, 2007 | 09:55 PM
dobbie146's Avatar
dobbie146
i have a dremmel, and some mechanical inclination...
how do you do it??
Old Jun 28, 2007 | 11:03 PM
mopowar's Avatar
mopowar
Use the pictures on ebay as a guide. Basically you cut the runners inside the plenum down. The more you cut, the higher the power band will shift (up to a point). Then you clean up the runner ports where you cut them with a grinder attachment. If you have a divider plate cut it out. Gasket matching refers to opening up the ports where they mate to the heads. You can also use a hardened bristle attachment on a flexible shaft to knock the slag off of the runner interiors.
Keep in mind that the one on ebay that you linked is the egr version.
I have run both a modified stock manifold and a M1. The M1 was way better on my truck, but I only compared the two after I installed a cam.
