gears
Old Jun 29, 2007 | 07:20 PM
ryans590's Avatar
ryans590
Default gears
ok i priced out my 4.10 gears today...anyone got a used set they wanna sell or know somewhere cheep lol..yah anyways i was told by the guy that i had to change my front carrer to fit the 4.10 in is this true? duz anyone know? i have 3.55 in there now
Old Jun 29, 2007 | 07:38 PM
dhvaughan's Avatar
dhvaughan
Default RE: gears
try these places.
http://www.performanceoffroadcenter.com/ call them with any questions.
http://www.ringpinion.com/Default.aspx
http://www.offroaders.com/tech/limit...ferentials.htm
Old Jun 30, 2007 | 03:17 AM
IndyRamMan's Avatar
IndyRamMan
Default RE: gears
yes, if you change one, you have to change the other.(so im told) I would guess if the x-fer case had diffrent ratios for front and rear you could run diffrent, but then youd have to upgrade them at the same intervals anyways, so its prolly even front and rear.
Old Jun 30, 2007 | 05:21 AM
ryans590's Avatar
ryans590
Default RE: gears
well i know i half to change the front and rear gears (ring and pinion) at the same time but i was told that the 4.10 ring woundent fit into the dana 44 in the front on the 3.55 carrer (because of the diffrent ring and pinion size) but i havent herd of this before then i was looking and i fould a 4.10 for the dana44 whitch was made to go onto a 3.73 carrer and lower because it was thicker ring so im just wondering if anyone has changed theres out and what exactley they used in the front
Old Jun 30, 2007 | 12:27 PM
WesV's Avatar
WesV
Default RE: gears
What you were told about the D44 is correct. D44s use 2 different carriers, one is for 3.73 and numerically lower gears (your 3.55s) included and the other is for numerically higher gears, 3.90, 4.10, 4.56 etc. The reason you have different carriers is because of the size of the ring gear in proportion to the pinion gear. Now that said the Jeep Rubicons use what is called a "thick set" gears on their D44 that allows the use of the 3.73 carrier with the 4.10 gears, but I don't know much about them, you might want to ask a jeep person, which ain't me...
Old Jun 30, 2007 | 05:50 PM
ryans590's Avatar
ryans590
Default RE: gears
yah i found a set of 4.10 gears made for the 3.73 and lower carrer and they were thicker, i think i would go that root unless anyone knows a reson not to the 4.10 thick set is only about $10 more, a lot cheper than a new carrer
Old Jun 30, 2007 | 08:13 PM
Socha_62's Avatar
Socha_62
Default RE: gears
You can just get Thick gears for the D44 instead of getting a new carrier. Its way cheaper and won't make any difference.
Old Jun 30, 2007 | 10:42 PM
ryans590's Avatar
ryans590
Default RE: gears
cool Socha thats what i was wondering thanks
now you wouldent know anyone with a set kickin arond they wanna get rid of eh
