What are the differences?
Old Jul 2, 2007 | 01:55 PM
dusty_duster's Avatar
dusty_duster
Default What are the differences?
So what are the differences between the 318 Magnum and the 360 Magnum? Is it just a different bottom end, or are the two motors completely different?
I'm asking this because I have a 318 and would love to eventually turn it into a 426 stroker...
Old Jul 2, 2007 | 03:42 PM
Sirhilton17's Avatar
Sirhilton17
Default RE: What are the differences?
The blocks are the same, same with the entire bottom end im pretty sure, I belive they have the same stroke with just a different bore.
Everythign is pretty much the same other than the different sizes.
Old Jul 3, 2007 | 12:17 AM
spaz_22's Avatar
spaz_22
the 318 is internally balanced and the 360 is externally balanced...and you also looking intoan 8 or so horsepower difference between the 318 and the 360
Old Jul 3, 2007 | 02:51 AM
froesen's Avatar
froesen
different main bearing sizes are the biggest difference in the bottom end other than the balancing. so no using cranks for 360 mains on a 318. best off finding a 360 block to start working with, all trans and mounting etc will be the same.
Old Jul 3, 2007 | 06:46 AM
Cereal Killer's Avatar
Cereal Killer
I'm pretty sure a 360 can only be stroked out as far as 408. Not sure about a 318.
Old Jul 3, 2007 | 08:04 AM
dusty_duster
So, if I wanted to do a build, I would have to get a 360 block?
ORIGINAL: Cereal Killer
Nope, it can be stroked to 426:
426-Stroker "HEMI-Sized"
