Supercharger boost shutdown
Old Jul 6, 2007 | 10:29 PM
  #21
lv360ram's Avatar
lv360ram
Default RE: Supercharger boost shutdown
[sm=oopssign.gif], my post was related to the combination of you and him.[sm=smiley18.gif]
I thought it was about your "rant" being on the revlimiter [sm=lol.gif] when you should have been posting about the fmu! Sorry.
Old Jul 6, 2007 | 10:43 PM
  #22
mopowar's Avatar
mopowar
Yah, I got off on a couple of rants today, but that doesn't help the guy with the 91 wrangler any. I guess I'l have to cut out now.
Old Jul 7, 2007 | 12:45 AM
  #23
Tani1500's Avatar
Tani1500
ORIGINAL: IndyRamMan
ORIGINAL: mopowar
All the money we get goes to Al Gore so he can buy his kids hybrids, thus enabling them to tear up the highways at 100mph all jacked up on drugs.
im sorry, your right, thats a much better cause. GOOOOOOO PRIUS!
(we do also retrain used lions as well, with the hopes of mauling color coordinated gay trainers.)
i got a better one. take it off and give it to your moderator so he can dispose of it before it kills your engine... i know best im tech certified [8D]
Old Jul 7, 2007 | 01:15 AM
  #24
spaz_22's Avatar
spaz_22
i was watching a video of a turbo charged 318...it was cutting out like it hit the rev limiter when it was just cruising, and it ended up being that map sensor going out of the pcms peremiters(SP?) anyways they added a resister and a diode, i'd look into that
Old Jul 7, 2007 | 01:27 AM
  #25
ryans590's Avatar
ryans590
ORIGINAL: Tani1500
what duz tech certified mean? (i know what a tech is i just dont know what exactley it i on this site) how did u get tech certifired
Old Jul 7, 2007 | 04:39 AM
  #26
froesen's Avatar
froesen
yeah, i watched that vid, i'm not sure what a zenier diode and a resistor would do for that problem as a 1-bar map sensor will read only that...1 bar, or 1 atmosphere, 14.7 psi i think, which is the highest pressure you'd ever see on an N/A motor (at WOT). you need a 2-bar or more sensor on a turbo or super motor as you're raising the manifold pressure ABOVE atmospheric. i have no idea how the stock computer would deal with that though, although if it's a supercharger kit i'd guess that it'd come with a sensor and computer mods...
Old Jul 7, 2007 | 06:17 PM
  #27
Tani1500's Avatar
Tani1500
ORIGINAL: ryans590
ORIGINAL: Tani1500
it means i actaully know what im talking about and not blowing **** out my *** the admins look for people they think are worthy of the title, for instance i just had them add one to rmindys
Old Jul 10, 2007 | 10:38 AM
  #28
91wrangler's Avatar
91wrangler
So you think it is the map sensor shutting the engine down because it is seeing too much boost? I will check the TV cable...I have not messed with that. I didn't think it was running that high of RPM, but it may have been.
Old Jul 10, 2007 | 11:12 AM
  #29
shott8283's Avatar
shott8283
does the motor literally just shut off.. meaning you have to pull over and start it back up again? or does it loose power?
do you know if your PCM has been programmed or flashed to except the boost?
Old Jul 10, 2007 | 11:18 AM
  #30
91wrangler's Avatar
91wrangler
It doesn't shut off like I have to pull over and start it, it just completely falls on its face. It feels like the fuel is shut off. It doesn't seem like a pop or miss fire, it literally feels like you shut it off.
And no, the PCM has not been touched. Nothing has been touched. I got ahold of the guy that installed the supercharger and he said that he put the FMU, inline pump, and supercharger on and away he went.
