no bus
Old Jul 10, 2007 | 10:54 PM
timwag2001's Avatar
timwag2001
Default no bus
my truck is pulling that no busbullsh!ton me. truck still runs, but dash and overhead console dont work. i'm getting 900, 920, 921, 940, 950, 999.
soo, i know i have to check to make sure the instr cluster is still plugged in and check for bad grounds... i've got a couple questions first.
can a fault in my aftermarket fan's electric system cause this? i doubt it but have to ask.
can a corroded pos battery terminal post cause this?
also when i was trying to lock my doors from the electric locksinside of the truck this weekend, my locks wouldnt move but they clicked along with a clickb from under the dash.
help me
Old Jul 11, 2007 | 12:51 AM
swirvin21's Avatar
swirvin21
Default RE: no bus
I kept blowing the run fuse in the engine compartment a while back and couldn't locate the cause. Don't know if it's the same since I never ran the codes, but my windows wouldn't operate and all dash functions died. Ended up being an internally shorted battery. Hopefully it's something simple like that. I ran wires and checked grounds for weeks without luck. Had to call Protech to find the problem, cost me $150 to buy a new battery......
Old Jul 11, 2007 | 03:45 PM
timwag2001's Avatar
timwag2001
Default RE: no bus
i have a melted wire going to my electric fan. could this be the problem?
Old Jul 11, 2007 | 05:06 PM
mopowar's Avatar
mopowar
Default RE: no bus
How did you wire the fans? Did you use a relay so they won't run when the truck is off?
Old Jul 11, 2007 | 05:20 PM
timwag2001's Avatar
timwag2001
Default RE: no bus
sort of... its a flexalite fan and the instr told me to tap to a power supply thats only on when the truck is on. that is what activates the switch. the fan get's its power directly from the battery though.
i tapped into a power supply for my brakes (i think its abs,if youre standing in front of your truck, its to the right of your master cylinder) so im sure theres a relay involved indirectly. the wire that melted is from a wire from the battery
