1997 Dodge Ram 1500 Turn Signal + Flasher Problems?
Old Jul 13, 2007 | 02:27 AM
adfatboy's Avatar
adfatboy
Default 1997 Dodge Ram 1500 Turn Signal + Flasher Problems?
hello evreybody i have bought the Switchback LED Bulbs soon to find out that i needed a flasher(blinker). well i bought an EL12 Led Flasher. i bought both items on autolumination.com, but i am clueless, when i installed the led bulbs for my front corner lights the turn signal got stuck, so i was thinking i need a special flasher, well i took a look inside my ram and look what type of flasher my ram had well the flasher only had two legs wich by the flashers that they have at autolumination.com the only match would be an EL12. well i installed the LED flasher that i bought and try it out with regular 3157 light bulbs, same problem, the turn signals got stuck, i plugg in my regular flasher and my turn signals work, i was wondering if i put in my led bulbs in front, will my back light bulbs would work. confused, anyone had this problem?
Old Mar 26, 2008 | 09:21 AM
jim1997's Avatar
jim1997
Default RE: 1997 Dodge Ram 1500 Turn Signal + Flasher Problems?
problem is two smaller wires at positive battery cable .the brass washer they are sodered to is corrored behind the bolt on the cable
