46RE Front Band Adj. Question
Old Jul 15, 2007 | 10:50 PM
cobradriver's Avatar
cobradriver
Default 46RE Front Band Adj. Question
Ok so I went to adjust the front band and removed the adjuster to clean and lube it, now putting it back in, it goes ALL THE WAY IN.
Is it because something released inside when I took the adjuster out?
Thanx for any and all help
CD
Old Jul 16, 2007 | 01:31 PM
rabbler's Avatar
rabbler
Default RE: 46RE Front Band Adj. Question
Yup, something fell off there is another part between the bolt and the band (wedge shaped) and a metal strut .You will have to pull the pan and the valve body to access. DO NOT DRIVE until you repair!
Old Jul 16, 2007 | 03:29 PM
cobradriver
Good thing I thought twice about it because I was like "well if I fire up the engine, pressures will return to tranny and push back in whatever moved away"...........then I said "naaaaaaaaa just ask ppl more knowledgeable than yourself"
Thanx for the response, I've got jobs lined up this week and will get right on it.
CD
