Last edit by: IB Advertising
Browse all: Interior
- Dodge Ram 2nd Gen How to Replace Front Door Hinge Pin
Step by step instructions for the do-it-yourself repairs.
Door Hinge Pins
Hey, im new here and im just wondering if anyone knows how to remove the pins that go into the front door hinge. The door hasnt been shutting correctly and it looks as though the pins are shot and need replacing. Napa supplied the part and we got the door/ electrical to door off for easier access but it almost looks likethe pins are not replacable. I tried searching in the DIY and couldnt find anything. let me know. Thanks
The factory pins are blunted at the top and either need to be drilled or cut out they are removed from the bottom not the top of the door. It is not a bad job I have done them on my truck. Did your kit come with new bushings? They make oversised ones if you need them and it is usually the bushings that are bad not the pins. Good luck!
