hypertech or superchip?
Old Jul 16, 2007 | 07:51 PM
desert dodge's Avatar
desert dodge
Default hypertech or superchip?
for a 5.9 which programmer delivers better results?
Old Jul 16, 2007 | 08:03 PM
citygasdude's Avatar
citygasdude
Default RE: hypertech or superchip?
I went with the hypertech, I didnt notice a big difference but I set it for 85 octane on the gas since Im at 6400 above sea level and I also reset the speedo for the bigger tires since my gps was telling me I was off about 8 mph. I havent tried it yet for higher octane gas.You can reset your rev limiter and also shift points I believe.
Old Jul 16, 2007 | 08:07 PM
lv360ram's Avatar
lv360ram
I am happy with Superchips.
Old Jul 16, 2007 | 08:25 PM
desert dodge
superchips claims somewhere around 46hp/49lbft does this sound about right?
i didnt find stats on the hypertech
Old Jul 16, 2007 | 09:19 PM
ryans590's Avatar
ryans590
there both good, i have superchip and am happy with it and the guys who have hypertech will tell you the same, there stats are compareable as well if you do a serch here on the 2 you will find tons of info this is a common question. generley hypertech is a little cheper, id go with whitch ever you can get a better deal on
Old Jul 16, 2007 | 09:56 PM
rhaines00ram's Avatar
rhaines00ram
Can you set your shift points ? If so i have to get one I dont like how soon mine shifts onto overdrive
Old Jul 16, 2007 | 10:24 PM
cdusthockey's Avatar
cdusthockey
No, our tranny is not electronically controlled
Old Jul 16, 2007 | 10:40 PM
lv360ram's Avatar
lv360ram
ORIGINAL: rhaines00ram
Try adjusting the tranny cable by moving the cable housing toward the firewall. That will cause the engine to rev slightly higher before shifting into the next gear. Moving it 1/16" can make a noticable difference. I kept adjusting mine until I got a nice shift pattern.
Old Jul 16, 2007 | 11:30 PM
Silver_Dodge's Avatar
Silver_Dodge
A Mopar Performance PCM was better then the Hypertech I had, and the B&G flash I have now blows them all away. If performance is what your after, save your money up and get the flash. It is far superior. If you like the other features you get with the programmer (tire size adjuster, rev limiter, etc...), then go that route, but don't expect huge performance gains.
