mopar round air cleaner
Old Jul 17, 2007 | 01:42 AM
wayneo360's Avatar
wayneo360
Default mopar round air cleaner
i want to get one of these and i found one on jimsautoparts.com for like $70 and was wondering if anyone has found on any cheaper.. also does that kit come with everything? like wat about the vacuum lines that run from the stock air box to the intake manifold nd all that? i have an exhaust system and headers and im going to open up my cat, will the air cleaner give it enough air or should i look into a tb spacer as well? thanks guys in advance
Old Jul 17, 2007 | 10:13 AM
JoeC1981's Avatar
JoeC1981
Default RE: mopar round air cleaner
Read this thread. It'll give you more info on the subject you'll ever need. I was able to get the round Mr. Gasket AC setup and K&N filter for under $70 from ebay. https://dodgeforum.com/m_613741/tm.htm
Old Jul 17, 2007 | 03:39 PM
mojo's Avatar
mojo
Ibought a 9" round eldelbrock air cleaner from autozone$39.95 and a K&N filter to fit it$36.99 and it works awsome. I went to the local junk yardand tookthe throtle body/air cleanerbolt off a3.9l Durango/Dekota cost me50 cents.I bought a breather for the nonPCV valve side of the motor and got rid of the hose, why would you want to rebreath in oil through the throtle body, a clean engine is a happy one.
