differential fluids
Old Jul 17, 2007 | 09:14 PM
reloader77724's Avatar
reloader77724
Default differential fluids
Heyyall, I've got a limited slip diff and my clutches are sticking, so I'm going to change the fluid and add some additive for the L/S diff. What fluid and additive(s) do yall recomend? Truck is in my sig.
Old Jul 17, 2007 | 09:16 PM
Socha_62's Avatar
Socha_62
Default RE: differential fluids
Theres only one additive for LSD. I guess theres different brands but I get whatever the parts store has. They're all the same
Old Jul 17, 2007 | 10:40 PM
RamMan4x4's Avatar
RamMan4x4
I bought mine from the dodge dealership, I think it was a 5oz bottle for $3-4. But I think any type of LSD additive will work
Old Jul 18, 2007 | 12:11 AM
rabbler's Avatar
rabbler
Any lsd additive will work. put the additive in first then fill with gear lube. 75/W90 conventional lube is the recommended lube 75/W140 synthetic is recommended if you tow frequently.
When your all done do some slow figure 8's in an empty parking lot or other large paved area. This will help pump the new lube between the clutches and should stop the chatter.
Old Jul 18, 2007 | 12:17 AM
Ironhide's Avatar
Ironhide
I'm pretty new to dodges do they come from the factory with a lsd??
Old Jul 18, 2007 | 12:46 AM
rabbler's Avatar
rabbler
It's an option not standard equipment, but it is common on the trucks
