Suggested Performance Mods
Old Jul 21, 2007 | 04:16 PM
95ramdan's Avatar
95ramdan
Default RE: Suggested Performance Mods
Is that Cat/Y pipe available for pre 96? I Have a 95, would that cat/y pipe work on mine?
Old Jul 21, 2007 | 04:20 PM
mopowar's Avatar
mopowar
Some guys are having problems with the 3923's. They work good to eliminate ping on a poorly maintained engine, but if your stuff is healthy, or you are modded a good bit, you may want to stick to the stock heat range. I had a low end stumble that I cured switching from 3923'sto NGK's of the proper heat range. Can't really say if it was the heat range or the brand though.
Old Jul 21, 2007 | 06:51 PM
Fox Fader's Avatar
Fox Fader
ORIGINAL: RM_Indy
Link below for the cat/ypipe at summit.
http://store.summitracing.com/partde...p;autoview=sku
Thanks for the y-pipe tip, I wasn't hip to that.
