Axle Shatf Oil seals?
Old Jul 19, 2007 | 09:27 PM
Moparkid032's Avatar
Moparkid032
Default Axle Shatf Oil seals?
Ok i n oticed the front Axle Shaft Oil seals went bad..REAL bad....and I am curious on how hard they are replcaing..i figure the hub will have to come off..but how hard is it to axctualy replace the seal..and where is it actualy located?? thanks
Old Jul 19, 2007 | 10:55 PM
dhvaughan's Avatar
dhvaughan
Default RE: Axle Shatf Oil seals?
drivers side is in the pumpkin. passenger side is at the cad.
hubs have to come out which is usually a man killer pita. the sealed, non servicable, very expensive bearings are prone to split apart and may have to be replaced before you roll again.
you could plan to do seals only, or you could go ahead and plan on bearings, u-joints, and ball joints if you like to only do it once. see the other tech articles on pavement.
http://www.pavementsucks.com/tech/axleseal.php
