Track Bar Replacement
Old Jul 24, 2007 | 07:01 AM
trappleye's Avatar
trappleye
Default Track Bar Replacement
I have a 2001 Dodge Ram 1500 4x4 AT STOCK with 70,000 miles. I determined that I needed a new track bar because the old one was shot and the stock ones are CRAP!!! I got my replacement track bar yesterday in the mail and I am currently trying to get the old one off and I can't. I have the front up on jackstands with the suspension at full droop, the nut with the cotter pin removed, and the bottom bolt also removed. I have bashed on the end of the bolt in the bushing with everything I can find and sprayed every kind of penetrating lube in there and it won't budge. HOW DO I GET IT OUT??????? Please help.
Old Jul 24, 2007 | 09:00 AM
trappleye's Avatar
trappleye
Default RE: Track Bar Replacement
I just gave up for the night. I tried putting the bottom bolt back in still with no luck. There must be something I am leaving out. Any suggestions would really be appreciated.
Old Jul 24, 2007 | 09:19 AM
rtmorrisjr's Avatar
rtmorrisjr
try heating it up and then hitting it out.
Old Jul 24, 2007 | 10:01 AM
defiantmopar's Avatar
defiantmopar
You dont need to heat it up just get a pickle fork and a B.F.H. That what it took to get mine off.
Good luck with that.
Old Jul 24, 2007 | 10:35 AM
echseman's Avatar
echseman
i used the pickle fork last night, and the end popped right out. don't hammer the bolt! it misshapes the hell out of the bolt. i had to re-shape and re-tap one of my bolts.
Old Jul 24, 2007 | 10:44 AM
steve05ram360's Avatar
steve05ram360
it is pressed in there pretty good... put a 3 legged gear puller on it and put some pressure on it. leave the nut on so when it pops it doesnt go flying.
which bar did you get?
I had one of these and had good results with it...
http://www.thurenfabrication.com/stocktb.html
Old Jul 24, 2007 | 10:53 AM
trappleye's Avatar
trappleye
I was wishing I had a pickle fork last night, but I don't have an air compressor. I've only seen the numatic ones, is there an option for a manual pickle fork? do you just hammer it in there? Also I don't care about misshaping the hell out of the bolt, I got an aftermarket track bar that I'm gonna be installing, and it has it's own bolt. So maybe the BFH is the way to go.
Old Jul 24, 2007 | 11:09 AM
defiantmopar
yeah just use a hammer and a normal pickle fork and hammer it in there. should pop it out after a couple of good wacks. it won't mishape anything unless you wack your thumb haha
Old Jan 1, 2008 | 04:26 PM
98DodgeRam1500's Avatar
98DodgeRam1500
its time for me to replace my track bar. You said you got an after market one, which one? and how well is it holding up?
I found soo many replacement options and none I can decide on.
First off, you can get the OEM style replacements from NAPA and MOOG - both have life time warranties, so you just have to buy one.
Then there is the Solid Steel Industries kits, the Lukes Links, Lindstat, and others...
ugh... should i just get the $140 napa replacement or spend $400 for one that i will never have to replace again.
I plan on only keeping the truck as my day to day commuter for 3yrs, then retire it as a work horse or trade it in.
Old Jan 1, 2008 | 05:15 PM
steve05ram360
I have used thurenfab bars and they hold up well. if you go with the moog bar, be prepared to be swapping it out every 25~30k... thats how long mine lasted.
